For "Auto Probe Calibration" . so i inserted below command. but while execution it calibrate angles, which are all used in this probe. i need to run only angles which are used in this program. how to set "Parameter Set' to calibrate angles used in this program?
i am using PC-DMIS 2019R2.
ALIGNMENT/END
MODE/MANUAL
PREHIT/0.1
RETRACT/0.1
MOVESPEED/ 100
SCANSPEED/100
LOADPROBE/PROBE_4
AUTOCALIBRATE/PROBE, PARAMETER_SET=ALL-TIPS-WITH-DEFAULTS, QUALTOOL_MOVED=NO,
CHECK COLLISION=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO
ALIGNMENT/END
MODE/MANUAL
PREHIT/0.1
RETRACT/0.1
MOVESPEED/ 100
SCANSPEED/100
LOADPROBE/PROBE_4
