Issue with Excel
  • Issue with Excel
    Issue Fixed
    I had a read only issue on one of the folders in the hierarchy where my program was saved.
    Unchecked read only and unchecked my show report box, re-saved program, issue is resolved.
    thanks for all of your help!
    __________________________________________________ __________________________________________________ __________________________________
    Using 2019 R2..
    I am trying to send dimensional data to an excel file in the background without my operators having to do anything.
    It works the first time (set up like you see in picture below). For part #2 and all subsequent parts in the run, PC DMIS keeps on automatically re-selecting the box that makes it "Show Report" and I have to click cancel when it keeps on wanting to pop up.
    This will SERIUOSLY screw me over when I go to loop this program.
    Don Ruggieri cvelisetty
    Do you have multiple print commands? And are you using the "Execution Report Print Setup" or using code print commands?
    • DAN_M
      DAN_M commented
      Yes, actually.
      I am using a print command for a custom PDF path. Is something below mesing me up? I am unfamiliar with the print command...just learned how to use it..
      ASSIGN/PROG_NAME=GETPROGRAMINFO ("PARTNAME")
                    ASSIGN/REPORT_NAME="O:\\CMM PROGRAMS\\CMM_PDF_PC DMIS\\AG04594_FINAL_01\\"+PROG_NAME+"__"+SERIALNUMBERQUESTION.INPUT+"-.PDF"
      PRINT/REPORT,EXEC MODE=END,$
                    TO_FILE=ON,AUTO=1,AUTO OPEN=OFF,$
                    TO_PRINTER=OFF,COPIES=1,$
                    TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=REPORT_NAME,$
                    REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$
                    TO_EXCEL=OFF,$
    • CodeWarrior
      CodeWarrior commented
      When having multiple print commands in a program, if you edit one of the two. Some of the settings will "stick" in the other print command.
      So maybe check the excel tab in the PDF print command to make sure the excel settings match the excel print command
    • DAN_M
      DAN_M commented
      issue resolved. See original post.
      thanks for all of your help!!!
    Are you saying that a dialog pops up, or Excel itself? What's your setting under F5, "Open report file when generated" - maybe that's interfering?
    Why not try an "Excel Form Report" - they can definitely be generated without any popups.
    • DAN_M
      DAN_M commented
      The program is supposed to have the "SHow Report" box NOT checked.
      After I run the program once, PC DMIS CHECKS it by itself.
      This results in the EXCEL report automatically opening after the program Is complete. I can't have this happening because my future intent is to loop this program.
    • DAN_M
      DAN_M commented
      Also, "Open Report File When Generated" IS NOT checked in my F5.
    • DAN_M
      DAN_M commented
    Doesn't happen to me in 2019 R2. Maybe some access restrictions to the part program folder so the settings don't stay?
    • DAN_M
      DAN_M commented
      If I go into my program folder, I actually see P2X files in there. I have never noticed them before and have no idea what they do.
      Is this part of my problem?
    • AndersI
      AndersI commented
      The P2X files contain the settings for the Excel export. Plain text, you could try write protecting them after verifying that they have the right settings.
    • DAN_M
      DAN_M commented
    go old school and use file/writelines.
    Before loop (This is formatted for output to measurlink, if you want all your data to output to one row, just comma separate each dimension):
    C_FILE =FILE/OPEN,C_PATH,APPEND
    ASSIGN/C_PATH="C:\PRODUCTION\customer\part name.CSV"
    ASSIGN/PART="Part Number"
    ASSIGN/ROUTINE="Part Number CMM Startup"
    ASSIGN/TRACE_FOLDER="Traceability-CMM"
    ASSIGN/CHAR_1="AA #7 Position "
    ASSIGN/CHAR_2="AB.1 #10 Position "
    ASSIGN/CHAR_3="AB.2 #10 Position "
    ASSIGN/CHAR_4="AC #9 Position "
    ASSIGN/CHAR_5="AD #11 Position "
    ASSIGN/CHAR_6="AE #64 Position "
    ASSIGN/CHAR_7="AF #69 Position "
    ASSIGN/CHAR_8="AG.1 #129 Position "
    ASSIGN/CHAR_9="AG.2 #129 Position "
    ASSIGN/CHAR_10="AH #143 Position "
    ASSIGN/CHAR_11="AJ #58 Position "
    ASSIGN/CHAR_12="AK #18 Position "
    LOT_NUM =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'Lot#?'
    CAV_1 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'What cavity is in station 1?'
    CAV_2 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'What cavity is in station 2?'
    CAV_3 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'What cavity is in station 3?'
    CAV_4 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'What cavity is in station 4?'
    USER =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'Operator?'
    SCHEDULE =COMMENT/INPUT,NO,FULL SCREEN=NO,
    'Scheduled inspection time?'
    ASSIGN/RUN_ID=LOT_NUM.INPUT
    ASSIGN/OPERATOR=USER.INPUT
    ASSIGN/TIME=SCHEDULE.INPUT
    FILE/WRITELINE,C_FILE,"/PART NUMBER/" + "," + PART
    FILE/WRITELINE,C_FILE,"/ROUTINE NAME/" + "," + ROUTINE
    FILE/WRITELINE,C_FILE,"/LOT#/" + "," + RUN_ID
    FILE/WRITELINE,C_FILE,"/OPERATOR/" + "," + TRACE_FOLDER + "," + "Operator" + "," + OPERATOR
    FILE/WRITELINE,C_FILE,"/SCHEDULED TIME/" + "," + TRACE_FOLDER + "," + "Scheduled Time" + "," + TIME
    FILE/CLOSE,C_FILE,KEEP
    Witihin loop, at beginning, I have a bunch of logic to assign POS as the part cavity id number and PNUM as the fixture position number.
    Loop contents
    At end of loop:
    FILE/WRITELINE,C_FILE,"/CAVITY ID/" + "," + TRACE_FOLDER + "," + "Position " + PNUM + "," + POS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_1 + PNUM + "," + AA.D.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_2 + PNUM + "," + AB_1.D.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_3 + PNUM + "," + AB_2.D.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_4 + PNUM + "," + AC.M.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_5 + PNUM + "," + AD.M.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_6 + PNUM + "," + AE.M.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_7 + PNUM + "," + AF.M.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_8 + PNUM + "," + AG_1.M.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_9 + PNUM + "," + AG_2.M.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_10 + PNUM + "," + AH.M.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_11 + PNUM + "," + AJ.M.MEAS
    FILE/WRITELINE,C_FILE,"/DATA/" + "," + CHAR_12 + PNUM + "," + AK.M.MEAS
    • DAN_M
      DAN_M commented
      I respect what you've done but NO THANKS lol that's a lot of typing
    • louisd
      louisd commented
      but once it is setup, it's rock-solid.
