I have some experience with coding my CMM, but recently I have been asked to determine the true position of a slot hole. Partially the drawing is calling out the TP for the front half of the slot hole but not the entire slot hole. I am trying to constrain the entire slot hole based on true position of 0.5. Previously we just measured the entire slot hole and created a center point but it was not accurate and gave random data. Currently I am simply measuring the front of the circle but I would like to control the entire slot hole. Pictures for reference. If there is anyway to assist me, please help me.
how to measure a slot hole
I don't think that callout is controlling one end of the slot, but the entire width of the slot. If you are using POSITION, you should be able to just use a single axis in the position dimension and all it will report is the deviation in that axis. DO NOT USE PERP TO C/L in the position dimension or it will use both directions.sigpic
Originally posted by szvincent010 View PostI have some experience with coding my CMM, but recently I have been asked to determine the true position of a slot hole. Partially the drawing is calling out the TP for the front half of the slot hole but not the entire slot hole. I am trying to constrain the entire slot hole based on true position of 0.5. Previously we just measured the entire slot hole and created a center point but it was not accurate and gave random data. Currently I am simply measuring the front of the circle but I would like to control the entire slot hole. Pictures for reference. If there is anyway to assist me, please help me.
Code:SLT_W =GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$ NOM/XYZ,<SLT_2.TX,SLT_2.TY,SLT_2.TZ>,$ MEAS/XYZ,<SLT_2.X,SLT_2.Y,SLT_2.Z>,$ NOM/IJK,<SLT_2.TI,SLT_2.TJ,SLT_2.TK>,$ MEAS/IJK,<SLT_2.I,SLT_2.J,SLT_2.K>,$ DIAMETER/SLT_2.TD,SLT_2.D SLT_L =GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$ NOM/XYZ,<SLT_2.TX,SLT_2.TY,SLT_2.TZ>,$ MEAS/XYZ,<SLT_2.X,SLT_2.Y,SLT_2.Z>,$ NOM/IJK,<SLT_2.TI,SLT_2.TJ,SLT_2.TK>,$ MEAS/IJK,<SLT_2.I,SLT_2.J,SLT_2.K>,$ DIAMETER/SLT_2.TL,SLT_2.L
- 1 like
I agree with Matthew D. Hoedeman and VinniUSMC about the width, but in this case, I don't understand why there's a "Ø" in the tolerance value...
- 1 like
Originally posted by JEFMAN View PostI agree with Matthew D. Hoedeman and VinniUSMC about the width, but in this case, I don't understand why there's a "Ø" in the tolerance value...sigpic
CUT & PASTE and fill in the blanks method of making a print. The FCF is a 'thing', for position, paste it in, fill in the blanks. Like bolts & nuts are in a cad package for designing tooling. They don't make a bolt model for every individual bolt, it is a 'menu item', paste it in location.
Hey, all, it's friday !
Have a nice week-end !
by billygwh3I am attempting to find hole "center" for an inside round slot auto feature on .090" thick sheet metal part. I use it all the time for...
12-02-2015, 05:09 PM -
I am having a problem measuring a slotted hole properly. The problem I am having is that the hole is slotted in both directions.
03-04-2015, 05:16 AM -
by Adam OlsonI have a slot or pocket whatever you want to call it which is datum -d-. My problem is that the slot is tapered (will attach a pic and print) and it does...
09-04-2008, 11:36 AM -
by markyFirst off, I'm running PC-DMIS 2011 MR1 and using a CAD model for programming.
I need some help understanding on how to check true position...-
07-31-2012, 08:57 PM -
by JLHUTTI am very new to this and I am sure it's a simple answer, but at the moment it has me stumped. I am checking a part that is a rectangle shape with a...
01-15-2008, 08:50 AM -
