scanning issues
  • scanning issues
    I'm having an issue and am at a lose on how to fix it.
    I have a program where i'm scanning a line on a groove face, theo's and vectors are correct and while the program is running the Y Actual is the same as the probe position readout. but as soon as the program is done and goes thru the calculations the Y, which should be at 0 or close to it, shifts anywhere from 1.4mm to 17mm on all the measured lines. workplane is Y plus from start of measuring the grooves to finish of the program, alignment is locked in all 6 degrees of freedom. when I run it as TTP Y stays 0. it only shifts when I try to scan the same lines.
    Can you post the code as a text, using the "#" button around it ?
      Don't know what version you're using, but I had problems with Line Scans and created a Case with Hexagon, There solution was "Huh??, It don't work, well don't use it." Now that's support at it's finest.
      I have seen this happening a lot in my Programs. It seems to be happening just with the Scanned lines, when done in mm. writing the programs, all fine and dandy, after running the program. It Projects my lines away from the part, giving me false readings. Will share my Code to show you the after results. Depth on all features
      • DB not cooper
        DB not cooper commented
        yep that's EXACTLY what mine does as well. glad to know it's a bug and not my programing LOL.
    • 2013_junkie
      Analog Scanning
      by 2013_junkie
      So first and foremost, I'm completely wet behind the ear with scanning. We have decided to add scanning to a few of our machines, so while we are waiting...
      01-08-2018, 11:53 AM
    • Ekneel28@gmail.com
      Scanning
      by [email protected]
      I am really struggling with scanning
      I have a profile I need to scan on a recessed O.D.
      I have tried all the different types of scanning...
      07-18-2019, 12:00 PM
    • Disal
      Another scanning post
      by Disal
      Sorry if this has been talked about before, i honestly didn't find anything that could help. I have a cylinder i'm trying to scan. It has a couple holes...
      11-14-2019, 10:19 AM
    • Darrollh
      Scanning Basics
      by Darrollh
      Good morning,
      I am beginning to get a few parts in that require scanning, something I have very little experience in. Can some help me with the...
      10-05-2017, 09:25 AM
    • ginnbob
      ginnbob
      by ginnbob
      I am doing a line scan of a radius in a hexalobe and then scanning all the way around the hexalobe. I am getting errors for each one. What can I do to...
      11-21-2019, 01:19 PM
