When I got to create a new auto feature my probe position in my graphic display window is stuck on whatever the last feature I picked was instead of where it actually is in relation to the part. Does anyone know how I can change this setting? I am currently using 2019r2
Probe position in graphic display window
I have been trying to reproduce what you describe. I am not seeing any drawing issues. I can work with you directly if you would like. My email is [email protected]
I have reported this issue in one of my mega threads, either the 2018 one or the 2019 one.
The issue (for me) is that every time I use an autofeature, the probe is displayed according to the entered nominals for the feature - not the probes actual position. Meaning, if I move the probe it will still stay at the autofeatures position (the values I have entered in the auofeature dialog).
This makes live positioning/adjustment impossible because the probe is locked to the autofeatures entered nominals.
rjurca
EDIT: Found the post:
https://www.pcdmisforum.com/forum/pc...179#post448179
Entered as PCD-164330.
Robert, please take your time to skim through these threads:
https://www.pcdmisforum.com/forum/pc...-r1-spx-issues
https://www.pcdmisforum.com/forum/pc...18-r2-releasedLast edited by vpt.se; 11-06-2019, 04:01 AM.PC-DMIS CAD++ 2o19 R1 SP11
Thanks, Robert.
I for one uses the "live positioning" when doing autofeatures without CAD. However, the later versions does not show actual probe position when autofeature dialog is open.
Suggestion:
If possible, the autofeature dialog should first display the probe according to the autofeature nominals - if the machine has been moved (read: run with joystick) the graphics window should "release" the probe from the autofeature nominal lock and reflect the probes current position. As long as the machine is standing still, the "autofeature nominal lock" can be active, but as soon as the machine moves, the lock should release and not activate again (for that autofeature). After hitting "Create", enable the lock again for the next feature. Maybe enable lock every time a nominal value is edited?PC-DMIS CAD++ 2o19 R1 SP11
I disagree with the quick feature solution - as it will only work when using a CAD model. The times you are not using CAD, the quick feature solution won't work.
We need the actual probe positioning to be shown live in the graphics window when autofeature dialog is open in order to "navigate" in the unknown... (cue eerie music)PC-DMIS CAD++ 2o19 R1 SP11
by DAN_MUsing 2020 R1 SP1...
How do you change the size of the arrows in your graphic display window when you make the feature via probe mode? Drawing...-
03-25-2020, 11:49 AM -
Hello, does anybody remember how to make the black hit dots on the graphic display window small? I remeber geing tought this in the class but it been...
Channel: Tips & Tricks
11-19-2014, 03:52 PM -
by ADAM WALLACEI don't know what I did but I can't seem to get my probe to move in my grphic display during exacution of the program. any help would be apprecaited ...
12-10-2013, 11:09 AM -
When doing auto circles in version 4.3 the probe appears in the graphic display window and I can’t see anything underneath it. I can’t figure out...
06-09-2009, 04:57 PM -
by ginnbobHow do I turn the grid display off? somehow i turned it on by accident.
01-27-2021, 11:10 AM -
