Try swapping out the extension(s)/tip(s) and try again. You can narrow down if it's due to a module going bad or the extension/tip that is going bad. Also, make sure you don't have too long/heavy of a tip for the particular module you are using! You could also add a few more points to the calibration routine. I've also lowered my STD by a few tenths from changing from 13 hits to 17 hits for calibration.
Thanks guys. I’m using a smart standard force module. I’ve change the stylus and got the same results. I’m going try increasing the hits and doing a thorough cleaning. Thanks you all!!
When I was going through calibration this morning I noticed that I was getting consistantly .0002-.0003 StdDev on all angles using a Med. force Module....
I have tried everything on this 0.7MM X 20MM Probe. I purchased 1 of these probes, calibrated it as few as 7 hits as far up as 75 hits. Readings were...
Looking through our shop floor calibration records, I am seeing a higher than normal standard deviation on the probes using the SM25-2 module. The probes...
I have a cmm brown and sharpe that has all of a sudden gone wonky. Renishaw ph10 convert 30mm to 8mm thread ph2 all parts have been cleaned used 2 different...
