To simplify what I'm doing, let's say I have a measured point with a +Z vector, a feature set containing that point, and a formandlocation profile of that feature set reporting a deviation of 0.43mm. Now, I want to evaluate that profile in another alignment. So I add an alignment with a 100mm Z translation, create a new profile and use the previous feature set again reporting a deviation of 0.43mm.
The 2 profiles report exactly the same deviation. I would expect that the deviation of the second profile would report an additional 100mm of deviation in Z, but it does not.
However, if I do the same trial with a location dimension, the deviation shows the additional 100mm.
What am I missing? It appears that the location dimension does not update the nominal, but the profile dimension does. Why would the profile dimension do that? Is there a way to stop it, and make it behave like the location dimension? I need to see the effect the second alignment has on the profile, but it's not reflected in the deviation.
Thanks!!
Thanks!!
