Hey folks,
I'm doing an alignment on a part and I can't get it to lock in correctly. I assume I'm either doing something wrong, or the model is incorrect.
The picture is a rough sketch of the idea of what I'm working with.
Datum B is a hole punched through the metal.
Datum A is 3 locations to take points from to construct a plane for leveling.
Datum C is based off of a surface with a draft that butts up against a spring loaded pin on the gauge to hold the part in place.
I've tried a few different approaches including:
Assuming the CAD I'm working with is correct, is there something else I should be doing or is one, (or are a few,) of those approaches correct, and which?
I would have thought a line constructed between two edge points along the bottom edge of the drafted surface was the best solution.
I'm using Iterative alignment to keep the part in car body position, and it keeps throwing my Datum B circle off to the right and up when I execute the alignment as well as acting like the surface of Datum C is off location.
Thanks in advance again!
- Measuring 2 edge points along the bottom of the draft surface and rotating to that.
- Measuring a plane for Datum C on that draft surface and rotating between a constructed point and Datum B.
- Using the gauge model to plot the exact center of where the pin sits against a nominal part to use as a rotation point between it and Datum B.
