I've got a part here that requires hundreds of inspections, so we created a fixture to run 15 of the parts in one execution so i'm not required to come back to the CMM every few minutes. I've hit a wall though where I need my reports to print per part and NOT have the previous part's dimensions. In other words, after each print command I want my results at that specific point in the program to be cleared so the next part's results will be the only results in the next report. This is important because I am going to import my results into another software for my Final Inspection Reports, and the software will only pick up the first part's dimensions if all the results are in one file. I'm a novice user, so if this will require any expressions/assign commands I will need as much explanation as possible. Thanks for any help!
