Parameter Set AutoCal
  • Parameter Set AutoCal
    I've searched the forum for a day or two, but I haven't found a thread that answers my question.
    I use autocal commands in all my problems. I track the dates and times for the calibration of these tip sets in an external file. Based on a time interval, the calibration is triggered. I was asking a programmer friend yesterday if it was possible to pull the date and time of the last calibration directly from PC-DMIS.
    The data is there in the active tip list. My question is how to pull it out. I imagine it will be something like:
    ASSIGN/QCOM=GETCOMMAND("LOADPROBE","DOWN",1)
                ASSIGN/VPRBNAME=GETTEXT("LOADPROBE",0,QCOM)
    Anyone out there tried to do this?
    Negative, Ghostrider...the pattern is full...
    ASSIGN/V1=PROBEDATA("Date", "tipID", "probefilename")
    ASSIGN/V2=PROBEDATA("Time", "tipID", "probefilename")
    • Rookie
      Rookie commented
      Thank you Anders!
    How to go about getting a tip from a parameter set in the autocal command?
      The tip Id come from the probe file, not from the autocal.
      If you have a set with T1A0B0 and T1A90B90, called set1, for example, then type "T1A0B0" to get A0B0 results.
      You will have the same number of asignments than the number of tip angles.
      • Rookie
        Rookie commented
        Yea I knew the tip ID is independent of the autocal command. I was wondering if there was a way of getting the individual tip data based on the parameter set. According to the next post from Anders, there's no way of doing that.
      I don't know of any way to read parameter sets. You can get the currently selected tip with GETPROBEDATA("ID"), but I have found nothing referencing parameter sets :-(
      The type library (automation) does not contain anything about probe files except the name of the current one.
      I can't even find a way to enumerate the tips (angles) in a probe file - if we had that, it would be possible to discover uncalibrated angles, and other interesting(?) things...
      • Rookie
        Rookie commented
        Anders, I'm using this code, but I can't get the text of the name of the probe. Any ideas?
        ASSIGN/VPRBCMD=GETCOMMAND("LOAD PROBE","DOWN",1)
                    ASSIGN/VPRBNAME=GETTEXT("LOAD PROBE",0,VPRBCMD)
      • AndersI
        AndersI commented
        That's because the data type for the probe file name is "FILENAME" , not "LOAD PROBE".
        ASSIGN/V1=GETCOMMAND("LOAD PROBE", "UP")
        ASSIGN/V2=GETTEXT("FILENAME", 0, V1)
      • Rookie
        Rookie commented
        ...feeling kinda dumb right now...
        Why did I not think of that...?
        Thanks
      I'm searching the help file to find how to get the next probe file name. Not finding anything so far.
      • AndersI
        AndersI commented
        You increment the DOWN value until you get another name, or you put the code just before the next LOADPROBE command...
      Wanted to post what I came up with for those that are interested...
      I still ended up having to use an external log file to track the calibration date and times for the parameter sets, but this code is working like a charm:
      ASSIGN/VCALINTERVAL=VCALINTERVAL*100
                  ASSIGN/QCMD=GETCOMMAND("LOAD PROBE","DOWN",1)
                  ASSIGN/VPRBNAME=GETTEXT("FILENAME",0,QCMD)
                  ASSIGN/VMASTERCALTIME=PROBEDATA("TIME","T1A0B0",VPRBNAME)
                  ASSIGN/VMASTERCALDATE=PROBEDATA("DATE","T1A0B0",VPRBNAME)
                  ASSIGN/VMSTRCALHRS=ELEMENT(1,":",VMASTERCALTIME)
                  ASSIGN/VMSTRCALMINS=ELEMENT(2,":",VMASTERCALTIME)
                  ASSIGN/VMASTERCALTIME=VMSTRCALHRS*100+VMSTRCALMINS
                  ASSIGN/VCOMPDATE=SYSTEMDATE("MM/''dd/''yy")
      $$ NO,
                  ASSIGN/VMASTERCAL=0
                  ASSIGN/VTIMEDIFF=VCURRTIME-VMASTERCALTIME
                  IF/VTIMEDIFF>=VCALINTERVAL OR VMASTERCALDATE<>VCOMPDATE
                    ASSIGN/VMASTERCAL=1
                  END_IF/
                  SELECT/VMASTERCAL
                    CASE/1
      E_DELCALFILE    =FILE/EXISTS,VCALFILE
                      IF/E_DELCALFILE==1
                        FILE/DELETE,VCALFILE
                      END_IF/
                      LOADPROBE/HSP-X1H_MASTER
                      AUTOCALIBRATE/PROBE, PARAMETER_SET=HSP-X1H_MASTER, QUALTOOL_MOVED=YES_DCC,
                                    SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=YES
                      GOTO/L_CALROUTINE1
                    END_CASE/
                  END_SELECT/
      $$ NO,
                  AUTO CALIBRATION ROUTINES FOR THE PROGRAM PROBES
      $$ NO,
                  PROGRAM PROBE 1
                  - ROUTINE CHECKS THE CALIBRATION FILE FOR THE PARAMETER SET
                    FOR THIS PROBE
                  - CALIBRATION IS TRIGGERED IF TIME AND DATE CRITERIA ARE
                    NOT MET
      $$ NO,
                  -FINDS THE NEXT LOADPROBE COMMAND AND GETS THE PROBE
                   NAME.
                  -CHECKS FOR THE CALIBRATION LOG AND COMPARES
                   THE DATE AND TIME FOR THE PARAMETER SET
                   AGAINST THE CURRENT TIME/DATE AND THE CALIBRATION
                   INTERVAL.
                  ASSIGN/VREAD=""
                  ASSIGN/VPRBCAL=0
                  ASSIGN/QCOM=GETCOMMAND("AUTOCALIBRATE ACTIVE PROBE","DOWN",1)
                  ASSIGN/VPARAMSET=GETTEXT("PARAMETER SET",0,QCOM)
                  ASSIGN/VCURRTIME=SYSTEMTIME("HH''mm")
      E_CALFILE  =FILE/EXISTS,VCALFILE
                  IF/E_CALFILE==0
                    ASSIGN/VPRBCAL=1
                    GOTO/L_CALROUTINE1
                  END_IF/
                  ELSE/
        $$ NO,
                    -CHECK THE CAL LOG FOR THE PARAMETER SET NAME AND
                     PROBE NAME.
                    ASSIGN/C=0
      FPTR_CALFILE  =FILE/OPEN,VCALFILE,READ
                    WHILE/VREAD<>"EOF"
      VREAD          =FILE/READLINE,FPTR_CALFILE,{VFILEPRBNAME}+","+{VFILEPARAMSET}+","+{VCALDATE}+","+{VCALTIME}
                      SELECT/VFILEPRBNAME==VPRBNAME AND VFILEPARAMSET==VPARAMSET
                        CASE/1
                          ASSIGN/C=C+1
                          ASSIGN/VTIMEDIFF=VCURRTIME-VCALTIME
                          IF/VCALDATE<>VCURRDATE
                            ASSIGN/VPRBCAL=1
                          END_IF/
                          ELSE_IF/VTIMEDIFF>=VCALINTERVAL
                            ASSIGN/VPRBCAL=1
                          END_ELSEIF/
                        END_CASE/
                      END_SELECT/
                    END_WHILE/
                    FILE/CLOSE,FPTR_CALFILE,KEEP
                  END_ELSE/
                  IF/C==0
                    ASSIGN/VPRBCAL=1
                  END_IF/
      $$ NO,
                  -ROUTINE FOR THE AUTO CALIBRATION
      L_CALROUTINE1=LABEL/
                  FILE/CLOSE,VCALFILE,KEEP
                  SELECT/VPRBCAL
                    CASE/1
                      LOADPROBE/HSP-X1H_2X40
                      AUTOCALIBRATE/PROBE, PARAMETER_SET=HSP-X1H_2X40_A0B0, QUALTOOL_MOVED=NO,
      FPTR           =FILE/OPEN,VCALFILE,APPEND
                      FILE/WRITELINE,FPTR,VPRBNAME+","+VPARAMSET+","+VCURRDATE+","+VCURRTIME
                      FILE/CLOSE,FPTR,KEEP
                    END_CASE/
                  END_SELECT/
