I've found the answer to this before, but can't find it. Anyone remember what setting you change, to prevent PC-DMIS from reporting a Form Only profile out of tolerance, based on the min value?
Form Only Profile Reprting OOT
Form only would still be a min/max value. If you don't want a min value, perhaps you're looking for unilateral tolerance where the tolerance band is only in one direction?
In xact measure, you would click on the U and type whatever value your profile is.
- 1 like
I agree with Sora5. Profile dimensioned as form and location is bilateral unless stated otherwise. Form only is a one sided tolerance, but PC-DMIS will still report it as min/max if it is activated. If the min value exceeds half of your profile, it is out of tolerance. Even if you hit the F10 button, go to the dimension tab, and uncheck max/min, it will still show out of tolerance if the min exceeds half your tolerance. You just won't see the min value anymore. I always have that option checked for profile.
by Scott BrownGood Afternoon Everyone
Working on a part that has a 0.75mm profile callout with no datums. (Form only)(Profile|0.75| ) This tolerance is...-
12-06-2018, 04:55 PM -
hi guys, i'm stuck guessing again. i figured out how to finally get scanning to work and now when i want to check profile of a surface on the dialog box...
07-28-2009, 02:12 PM -
by newsitechrisSometimes while using PC-DMIS, I have a surface or line profile called out on the print. Say for example, a surface profile is called out 1/A/B/C. I...
06-28-2017, 09:29 AM -
by RobertoAmigos,
I am not thinking right this morning (too much tequila over the weekend)
Why am I seeing M1 and M in datapage for...-
04-30-2012, 03:09 PM -
by mfzaringAny insight into why it is using 2x the worst deviation for a form only profile? Bascially it is not allowing the tolerance band to move, which is the...
02-13-2020, 01:12 PM -
