Hello,
I am making programs for some of our tooling that require an extensive amount of hits.
These hits will be at different levels (varying the z axis) and will use the same x and y values.
I have been able to copy and paste the first set of hit points with a different z value by changing the alignment but the names are duplicates.
Is there an easy way to change all of the names from "LEVEL_1_PT1","LEVEL_1_PT2",etc... to " LEVEL_2_PT1","LEVEL_2_PT2",etc...?
Thank you and best regards,
Ahb723
Ahb723
