I transformed the CAD model to have the coordinate system be the same as the measured part. I also clicked the CAD = PART button after aligning everything. It worked, but the measured alignment features are pretty far away from the CAD Z origin. How do I bring that up to the origin (or is it the other way around)? I know there's a simple solution, but I'm a bit stumped as a greenhorn.
CAD Model Not Snapping To Measured Features and Alignment
Hello, I am a student who has been tasked with learning how to operate the CMM in the lab I work in. It has not been used in years, and the last person to operate it graduated 4+ years ago. I have created a program but when I go to automate it I get a machine error TR_PRB01, no probing within Probelimit. This occurs whenever
I successfully followed your instructions in the link provided (I created features while in Program Mode and then measured the part itself). While the circle and line actually line up with the CAD model, the actual workplane (Z) is pretty far down and away from the CAD model.
You're correct. Totally skipped that. Thanks.
by silvioHi everybody,
I am starting to use our new acquired CMM arm. My question is about the use of the imported CAD model in PC-DMIS measurement...-
08-14-2019, 07:43 AM -
by Joe ArnoldWhen a cad model is used for programing - is the sequence of programing the same as a program without a cad model ?
First define some...-
10-25-2007, 04:38 PM -
by ramir22I am trying to create a 3-2-1 alignment on the press panel shown in the CAD picture. I usually do it over in a fixture gauge but due to technical issue...
05-16-2013, 06:07 PM -
by lcrowstonFor some reason the CAD model will not sync up after DCC alignment. I have never had this happen before. Please help....
05-03-2019, 11:21 AM -
by humbertoi had a program done using cad, and then try to create a local ref. sys. from measured features, everything worked good up to that point untill i hit...
02-08-2012, 07:46 PM -
