In Pc dims I am trying to define the probe( Brand new CMM ). In the drop down menu I select a HH-AS8-T2.5 . After that I highlight and click on the drop down menu and I am looking for HP-S-X1H ( M00-114-042-020) or along those lines. The problem is that there is nothing in the drop down with anything like that. What do you do in this case?
Defining a probe
I believe you will need to look for something like this. probe definition.JPG
My probe is labeled HP-S-X1H on the probe body it self but to creat the probe I had to select what you see in the first "Connect" line. If you look towards the end of the first Connect line you will see the name of the probe. This is how the technician showed me to create probes.
Hexagon, in their infinite wisdom, implemented TWO DIFFERENT HP-S-X1H rack designs, with identical part numbers, which have approximately a 2mm delta in Z height to the little probe rack docking pin. That being said, there's a setting within FDC which will need to be toggled, "X1Changertype" needs to be changed from a 0 to a 1.
https://www.pcdmisforum.com/forum/pc...leitz-hp-s-x1hLast edited by louisd; 10-21-2019, 03:09 PM.
- 1 like
by Moore RacingI recently downloaded a new pcdmis software.. 2017 R1 when I go to build a probe file, there's no probes or head etc to build a probe file..
The...-
12-14-2017, 09:25 AM -
by Moore RacingI'm having a problem finding a certain pc. of hardware on the probe build drop down list... Starting with the HHA M5 head... That's fine.( it show's the...
08-10-2016, 09:09 AM -
I bought new probes a week or so ago. I went to use one and was trying to set one up in my probe dialog box. My new probe isnt listed in the drop down....
03-25-2014, 02:07 PM -
by kberryProbe Description Empty
The probe description box is empty when I want to build a new probe or edit an exsiting probe. No head,...-
08-19-2008, 01:24 PM -
by NfiskI would like to chang my 2X20 probe to the 1MM stylus, but I do not know what the program is calling it in order to qualify the stylus. I have a good...
01-18-2008, 03:51 PM -
