How do i make a set of motion parameters a default setting? Like making my move speed 120 and touch speed 5. Every time i open a new program its 20 and 1.
Default settings
If you want the machines to default to a specific speed, hit F5-Find the tab that states the movespeed/touchspeed- change it to your desired value-then hit the button that says "default." (I'm not at my computer, it could be labeled "defaults.") Each tab has this button and once hit, saves the current settings as default. F10 settings also.
Keep in mind, most programs have those settings, along with others, defined and are program specific. If you change the value on the CMM it most likely will not effect the programs at all. You'd have to go in each program and change them manually. You may be able to find someone on here that can point you to a script that can do that automatically. People here are resourceful.
Also, If you change the touch speed on your programs, you would need to re-calibrate your probes to the new touch speed otherwise you can introduce error in measurement.
by keegoWe just bought a new Global Advantage 12-22-10 with PC-Dmis CAD++ 4.3 and it is set on extreme turtle mode. How do I change its default move speed and...
11-26-2008, 08:20 AM -
by Jonde1Is there a way of changing the default speed on our machine? We have just upgraded to Pc-dmis cad++ 2014 and realise that the machine moves a lot slower...
03-06-2015, 01:22 AM -
by FredMDI recently had a hard drive that was failing so we installed a new hard drive and migrated the PCDMIS settings over. Now my move speeds are dramatically...
05-28-2019, 10:49 AM -
by giantslayerI have a program given to us by a customer, I run my calibration and programs in percentage speed. I want my program speed to match the calibration speed/hit...
06-15-2017, 04:08 PM -
by QinspWe set the movement speed to default at 100% in Parameters of v4.2.
The machine won't go faster that 20% actual speed regardless of how...-
10-02-2014, 01:27 PM -
