Hopefully an easy one, I just need to save my program as a .txt file so that I can email it. Right now outlook will corrupt the file when sent.
save prg as .txt
by Justin CI need to export or save a program to send it via email so a colleage can review it, I was told to save it as a txt. file but I'm not sure how to do this....
04-11-2017, 04:20 PM -
Using 2010 MR2...I go to file>operations>rename select my file, change the serial number then hit save. Pcdmis error says unable to save file....
04-27-2012, 12:48 PM -
by AtokadProblem Solved! (Sort of…)
The problem I was facing is that there is no way to get PC DMIS to output a text file extension in lowercase....-
05-09-2017, 04:16 PM -
by robehor4How do you change a .txt file to an .exe file? There are some codes I would like to try yhat have been posted.
Thanks-
01-04-2008, 06:04 PM -
by drako28I'm trying to get this to work..... But when I try and go the other way across it doesn't report the numbers just the text.... Does anyone know how...
11-16-2007, 09:36 AM -
