I have been struggling making a 6 cavity program into a 8 cavity. I have used the same alignment method for the other 6 to complete 7 & 8. I can get through the entire program except the last item on cavity 8. I believe it may be an alignment issue but I cannot seem to pinpoint where it went faulty. The actual's for cavity 8 are way off, meanwhile 1-7 are spot on.... I have attached the program code and a screenshot to show what I am working with. Any help will be greatly appreciated!!!!
Error "Position out of machine stroke limit Y-Axis"
It was throwing the error out on a move/clearplane. However, I deleted it and manually positioned the probe around 1mm away from the target, tried to execute and received the same error message. I must also say that the clear plane is -30mm on the machine grid plate I have -125mm until the end of my measurement zone.
Upon looking at your code, your initial alignment is aligning X and Z to MAN_PLN which is your X Level.
I don't know how the last translation of Z axis to MAN_LIN helps or not (might be saving you!), but this is definitely an error.
Code:MAN_AL =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,XPLUS,MAN_PLN ALIGNMENT/ROTATE,YPLUS,TO,MAN_LIN,ABOUT,XPLUS ALIGNMENT/TRANS,XAXIS,MAN_PLN ALIGNMENT/TRANS,ZAXIS,MAN_PLN ALIGNMENT/TRANS,YAXIS,MAN_PNT ALIGNMENT/TRANS,ZAXIS,MAN_LIN ALIGNMENT/END
LETTERS_NUMB3RS_UNDERSCORES only in feature and alignment ID's (unless intentionally coded with active fomulas) RENAME THEM.
It seems all your cavity alignments within the loop are recalling FIX_A1, which seems to be the location of the first part... not a generic back to the fixture.
Right where your screenshot of where it stalled, it's saying you are trying to over-travel in Y.... First hit of feature ID "CAV_8_16.08_PLN" below....
It seems like your theo's and Actuals don't match at all for where this plane is located.
Code:AL_ST_8_X_DATUM =ALIGNMENT/START,RECALL:CAV_7_11.31_ALN,LIST=YES ALIGNMENT/TRANS,YAXIS,CAV 8_DIA ALIGNMENT/TRANS,ZAXIS,CAV 8_DIA ALIGNMENT/TRANS,XAXIS,CAV_8_X_DATUM ALIGNMENT/END MOVE/CLEARPLANE CAV_8_11.31 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<-16.65,0,0>,<-1,0,0>,11.31 ACTL/<-16.65,0.007,0.033>,<-1,0,0>,11.172 TARG/<-16.65,0,0>,<-1,0,0> START ANG=120,END ANG=240 ANGLE VEC=<0.0069459,0,-0.9999759> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=3,DEPTH=0,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=10 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO CHECK/10,1 CAV_8_11.31_ALN =ALIGNMENT/START,RECALL:AL_ST_8_X_DATUM,LIST=YES ALIGNMENT/TRANS,YAXIS,CAV_8_11.31 ALIGNMENT/TRANS,ZAXIS,CAV_8_11.31 ALIGNMENT/END CAV_8_16.08_PLN =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<-16.08,0,2.8>,<-1,0,0> ACTL/<-16.08,0,2.8>,<-1,0,0> MEAS/PLANE,3 MOVE/CLEARPLANE HIT/BASIC,NORMAL,<-16.08,5,1.7>,<-1,0,0>,<-98.219,-1070.671,213.116>,USE THEO=YES HIT/BASIC,NORMAL,<-16.08,0,5>,<-1,0,0>,<-98.217,-1075.555,216.418>,USE THEO=YES HIT/BASIC,NORMAL,<-16.08,-5,1.7>,<-1,0,0>,<-98.22,-1080.539,213.12>,USE THEO=YES ENDMEAS/ MOVE/CLEARPLANE MOVE/POINT,NORMAL,<-68.471,877.066,-92.077>
Open this routine offline (open one routine online, then open this one in front of the online routine).
Change your loop count to 1
Execute it.
Make sure this feature's measured values go back to theo. exact location.
Change loop back to your 40whatever
Save routine.
set it as read only.
run it again.
any time you make changes within a loop, you want to make sure your counter is set to 1.
in my opinoin, i would have made a 1 cavity routine to measure one part, then looped it. It guarantees you aren't programming bias into any of the fixture positions, and cuts your workload by a factor of 8 for future revisions, lol...
I 100% agree, this program is around 6 years old and I have only 3 years of experience. This one is ruff!!
by Burr2222I have a part program that I finished & ran about a dozen times last week with no hickups. This week when I had our QA tech start running the program...
05-08-2018, 05:54 PM -
by JHamm21Ok so I'm getting the error in the title. Machine is completely down, I can't do anything as of now and have a cap study due tomorrow. Anyone know what...
12-29-2015, 11:47 AM -
by mx07423I'm coming across this error when i running the program "TR_FG152.Z lxT" I don't know what the error is but it happens every part right before...
08-24-2007, 05:36 AM -
by DaSaloI have had this happen a couple of times now: I create a program using my offline seat using move points (not move increment) for my positioning moves....
09-10-2011, 11:24 PM -
