True Position of threads
  • True Position of threads
    Hello,
    What are some ways to check true position of threads. (5/8-11 UNC-2B TAP THRU)
    Also, having trouble applying this to the Feature Control Frame Editor. (threads specifically)
    Hopefully someone else knows how to execute this task.
    You can use True position locators or apply lead to the measurement.Also remember that probe diameter needs to be adequate.
    Medical Component & Product Manufacturing Paragon Medical works with ambitious medical manufacturers, helping accelerate new product development with medical device manufacturing and high-precision components for everything from implants and surgical instrumentation to single-use disposable devices and assemblies. Our divisions will partner with you to refine your designs, improving performance and
    Time for the Trolls to leave.
      When checking threads, use the pitch setting in the auto circle feature. That’s the best way to do it if you don’t have locators. Another way is to use a shank probe but when you use a shank probe, make very certain you touch the sphere at A0BO and it’s perfect. If not, you will have a hard time qualifying or may have bad parts.
      Darroll
      2018R2
        I've gotten this answer from a member here forgot what his name was or i would give credit.
        Create a linear open scan along the bottom of the thread. It doesn't need to be long, just long enough to find the Minor diameter. Create a generic point to the highest point on that scan using "max index". Create an auto cylinder change the pitch to the correct pitch for the thread. Now edit the starting point of the cylinder and use the generic point. This will ensure your probe will always start on the Minor diameter giving you better results.
        SCN7       =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=17,SHOW HITS=NO,SHOWALLPARAMS=YES
                    EXEC MODE=DEFINED, NOMS MODE=NOMINALS,CLEARPLANE=NO,SINGLE POINT=NO,THICKNESS=0
                    FINDNOMS=0.15,SELECTEDONLY=YES,USEBESTFIT=NO,PROBECOMP=YES,AVOIDANCE MOVE=NO,DISTANCE=0,CAD Compensation=NO,4-axis scan=NO
                    DIR1=NULLFILTER,
                    HITTYPE=VECTOR
                    INITVEC=0.0019256,0,0.9999982
                    DIRVEC=0,1,0
                    CUTVEC=-0.9999982,0,0.0019256
                    ENDVEC=0.0019256,0,0.9999982
                    PLANEVEC=0,-1,0
                    POINT1=0,-0.477,-2.698
                    POINT2=0,-0.4228,-2.698
                    MEAS/SCAN
                      BASICSCAN/LINE,NUMBER OF HITS=17,SHOW HITS=NO,SHOWALLPARAMS=YES
                      <0,-0.477,-2.698>,<0,-0.4228,-2.698>,CutVec=-0.9999982,0,0.0019256,DirVec=0,1,0
                      InitVec=0,0,1,EndVec=0,0,1,THICKNESS=0
                      FILTER/NULLFILTER,
                      EXEC MODE=DEFINED
                      BOUNDARY/PLANE,<0,-0.4228,-2.698>,PlaneVec=0,-1,0,Crossings=1
                      HITTYPE/VECTOR
                      NOMS MODE=NOM,0.15
                      ENDSCAN
                    ENDMEAS/
                    ASSIGN/V101=MAXINDEX(SCN7.HIT[1..SCN7.NUMHITS].Z)
        F3         =GENERIC/POINT,DEPENDENT,CARTESIAN,$
                    NOM/XYZ,<SCN7.HIT[V101].X,SCN7.HIT[V101].Y,SCN7.HIT[V101].Z>,$
                    MEAS/XYZ,<SCN7.HIT[V101].X,SCN7.HIT[V101].Y,SCN7.HIT[V101].Z>,$
                    NOM/IJK,<0,0,1>,$
                    MEAS/IJK,<0,0,1>
        CYL10      =FEAT/CONTACT/CYLINDER/ADAPTIVE_CYLINDER_SPIRAL_SCAN,CARTESIAN,IN,LEAST_SQR
                    THEO/<0,F3.Y,-2.63>,<0,-1,0>,0.136,0.1
                    ACTL/<-0.0002,-0.4479,-2.6298>,<0.0011409,-0.9999948,0.0030175>,0.1403,0.1
                    TARG/<0,-0.477,-2.63>,<0,-1,0>
                    START ANG=-90,END ANG=360
                    ANGLE VEC=<1,0,0>
                    DIRECTION=CW
                    SHOW FEATURE PARAMETERS=YES
                      VOID DETECTION=NO
                      REMEASURE=NO,USE THEO=NO
                      SURFACE=THICKNESS_NONE,0
                      MEASURE MODE=NOMINALS
                      RMEAS=NONE,NONE,NONE
                      AUTO WRIST=NO
                      CIRCULAR MOVES=STRAIGHT
                      GRAPHICAL ANALYSIS=NO
                      FEATURE LOCATOR=NO,NO,""
                    SHOW CONTACT PARAMETERS=YES
                      NUMHITS=5,NUMLEVELS=4,DEPTH=0,END OFFSET=0,PITCH=0.0321
                      SAMPLE METHOD=SAMPLE_HITS
                      SAMPLE HITS=0,SPACER=0
                      AVOIDANCE MOVE=NO,DISTANCE=0.3937
                    SHOW HITS=NO
        • Jakep379
          Jakep379 commented
          i use this on all threads regardless of Tol just because it is extremely repeatable. However most of our Tol on threads have a .005 thou position. This doesn't require alot of time either once u do a few becomes pretty fast.
        • asroma
          asroma commented
          When you said "along the thread", do you mean a horizontal scan or a vertical scan? Also, when I set this up offline, it looks like my cylinder isn't centered to the threaded hole on the CAD anymore. Is this normal?
        • louisd
          louisd commented
          Your goal is to take an array of hits (or a scan) along a radial cross-section of the threads.
          -I generally take a scan of hits that's 0.005" increments along a length of three pitches worth, just to be certain i get the actual point i need.
          --You would then extract the hit you feel you need to take. You can use that MAXINDEX or MININDEX to judge the pitch diameter (between minors), or the minor thread pitch. of course you will never get an accurate diameter for the PD, but if your minor thread is burred up or choppy, you can invert this assign max/min index function to zero your start point to probe directly in the middle of the minor's as applies.
