Low Force Probe for Flatness
  • Low Force Probe for Flatness
    Hello, I have a piece of poly styrene with L=17", W=7", thickness 0.050". I use 1MM cylinder probe for checking 0.190" holes ID and measure flatness. The problem is the part is so thin, the probe actually pushes the surface down prior to acknowledge the contact points. My CMM is B&S Global performance 555 with M2 touch probe. Can anyone recommend better type of probe? I thank you in advance.
    Got an indexable head? Rotate up to A60 or A75 to take the flatness hits.
      I would use a regular probe. I’ve never had much luck dealing with cylinder probes. At worst, I would use a shank probe but be care when you go to calibrate. You have to make certain you’re coming in normal to the sphere.
      Darroll
      2018R2
        As Matthew D. Hoedeman sait, turning the probe will decrease the probing force.
        In the same way, using a long stylus will decrease the effort.
        More the ball will be large, less the Hertz pressure will be important.
        If you measure with a TP20 or Tesastar-p, take a low force module, and turn the head to have the minimal force up side A60B0 or A-60B180 doesn't give the same force on ttp...
        You can play with those parameters.
        • Schlag
          Flatness Per Unit Area
          by Schlag
          I am trying to dimension a Flatness with the per unit area option. The print is dimensioned at .005 Flatness and .002 per .1 x .1. I built the Feature...
          08-02-2011, 05:44 PM
        • grandpaal56
          Flatness
          by grandpaal56
          I have a part with a surface that is about 800mm long by 200mm wide the print is calling for a flatness overall on the surface of .05mm, and a zonal flatness...
          03-08-2011, 08:22 AM
        • bblessing
          Flatness
          by bblessing
          Quick Questions.
          When measuring Flatness of a Plate, Does it matter how flat the surface it is resting on is? If a plate isn't flat could the...
          06-07-2012, 08:55 AM
        • bw_bob
          How PC-DMIS calculates Flatness
          by bw_bob
          Allright guys help me out here.....heres what i got
          I'm running 3.5mr2
          the head is indexed at A=0 / B=O
          so all points are...
          01-13-2009, 04:11 PM
        • ptedrum
          Flatness Check?
          by ptedrum
          Typically how does one go about doing a flatness check of a surface with PC DMIS?
          07-31-2007, 09:34 AM
