In the box o'probes that came with our Leitz CMM came with a stylus joint that moves from 0 to 90 degrees. This would have been a perfect solution to an issue I have, but i can't figure out how to use it. If I put it on the 20x20 star cube and tighten it, unless it is at 0 degrees, there's now way to force it to have the attached stylus parallel to the Z axis. Basically, I get the right angle from stylus tip to joint bend, but the angle of the screw end of the joint isn't lining up so that the probe tip can be at 90,90. Am i missing an obvious thing here, or is this not intended to work the way I thought? Pics attached. In the pic with the stylus, the probe tip is supposed be parallel with the auto change rack to get me the right angle for this project. Thanks!
Derrick
Derrick
