Hi,
i'm trying to inspect same linear dimension and found that the feature id is turning into red color while renaming, also when i'm trying to call output for the same it says feature doesn't exists or the feature id in output turns red.
I have attached the snap of code.
is anyone else getting the same error or it's just me?
MOVE/CLEARPLANE PNT12.44_1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR THEO/<2.005,6,12.44>,<0,0,1> ACTL/<2.005,6,12.44>,<0,0,1> TARG/<2.005,6,12.44>,<0,0,1> SNAP=YES SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MOVE/CLEARPLANE PNT12.44_2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR THEO/<2.005,87,12.44>,<0,0,1> ACTL/<2.005,87,12.44>,<0,0,1> TARG/<2.005,87,12.44>,<0,0,1> SNAP=YES SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MOVE/CLEARPLANE PNT12.44_3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR THEO/<2.005,180,12.44>,<0,0,1> ACTL/<2.005,180,12.44>,<0,0,1> TARG/<2.005,180,12.44>,<0,0,1> SNAP=YES SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO MOVE/CLEARPLANE PNT12.44_4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR THEO/<2.005,273,12.44>,<0,0,1> ACTL/<2.005,273,12.44>,<0,0,1> TARG/<2.005,273,12.44>,<0,0,1> SNAP=YES SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.3937 SHOW HITS=NO WORKPLANE/XPLUS COMMENT/REPT, ************************** IMS NO. 78 DISTANCE 12.44 ± 0.006 ************************** DIM DIST97= 2D DISTANCE FROM POINT PNT12.44_1 TO POINT PNT_A1 PAR TO ZAXIS,NO_RADIUS UNITS=IN,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL M 12.4400 0.0060 0.0060 12.4400 0.0000 0.0000 --#-- DIM DIST98= 2D DISTANCE FROM POINT PNT12.44_1 TO POINT PNT_A1 PAR TO ZAXIS,NO_RADIUS UNITS=IN,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL M 12.4400 0.0060 0.0060 12.4400 0.0000 0.0000 --#-- DIM DIST99= 2D DISTANCE FROM POINT PNT12.44_2 TO POINT PNT_A1 PAR TO ZAXIS,NO_RADIUS UNITS=IN,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL M 12.4400 0.0060 0.0060 12.4400 0.0000 0.0000 --#-- DIM DIST100= 2D DISTANCE FROM POINT PNT12.44_1 TO POINT PNT_A1 PAR TO ZAXIS,NO_RADIUS UNITS=IN,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL M 12.4400 0.0060 0.0060 12.4400 0.0000 0.0000 --#--
