Hello all
When reporting a distance in PC DMIS i want to show the measured and acctual coordinate for both points in the axis it was measured.
I also want the nominal coordinate for the measured points to be 0.
So lets say I measure (Against CAD) two points on opposite facing planes. I report the distance between the points along Y-axis.. I want the operators to see which point is too far away from nominal value in the axis, (so if its ex. .023 mm or -0.023 mm.
Has anyone done this? Do I have to change alingment and set my orgin for each point/element that i measure? is there any smarter way?
Thanks for replies
Thanks for replies
