Good Morning! I am still very new to PC-DMIS and I am having trouble with the Xact measurement of a true position callout for a feature. The callout for the hole should read TP/ Ø.005 @ MMC/ A @ MMC but when I try to dimension it, it does not allow me to pick the MMC modifier for Datum A. Datum A is the plane that the hole lies on and is also my Z zero. Do I need to somehow dimension Datum A? Is there a way to add this modifier?
True Position MMC Callout
Since no one has mentioned it, I will point out that in ASME GD&T, when the M in a circle symbol appears in the DRF (Datum Reference Frame) portion of the FCF (Feature Control Frame), it is NOT MMC but rather MMB. The same applies to the L in a circle. The difference between Maximum Material Condition and Maximum Material Boundary is significant. MMC adds to the allowed tolerance. MMB allows datum shift.
HTH & ymmv
- 3 likes
I have a part with two datum holes b and c. There are other sets of holes with true position to a-b mmc-c mmc. In the true position dimension fcf, the...
02-15-2019, 01:59 PM -
by newsitechrisI would like to ask a question due to the fact that me & some of my coworkers are having a debate & cannot come to a definitive answer - I was...
06-08-2018, 02:23 PM -
When I am calling out a true position of a feature and I use a datum with a MMC a Ø symbol appears. Do I put in the MMC of that datum or will pc-dmis...
07-20-2015, 11:33 AM -
by kingsld1So....
Here's the situation.
QA in its infinite wisdom, has decreed that we can no longer use Word to create inspection checklists....-
07-16-2018, 06:15 PM -
by Rush2112-A- and -B- are two coaxial features with -C- being the through hole. how can i use both "A" and "B" as one datum with separate mmc...
09-06-2017, 02:28 PM -
