Reporting Analysis in a loop
  • Reporting Analysis in a loop
    We are having issues with measuring parts within a loop as we need to export the graphical analysis for each part measured to report on a bore at various heights. We are looking to run 24 parts overnight with a ten minute run time for each which it can do but the graphical analysis is as expected only for the first part but for the other parts measured within the loop the image is tiny and not always central or cocked over. What needs to happen is that after exporting at the end of the loop the data is reset and clean for the next part so so and so on.
    Pulling our hair out on this one
    Is the external command for the analysis before or after the "Loop End" command?
      cant you simply insert a print/report command at end of your loop, and set it to output to PDF.
      for previous runs= set it to DELETE_INSTANCES ?
      PRINT/REPORT,EXEC MODE=END,$
                    TO_FILE=ON,AUTO=1,$
                    TO_PRINTER=OFF,$
                    REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$
      [B]PREVIOUS_RUNS=DELETE_INSTANCES[/B]
                    LOOP/END
        Cheers for the replies. We have the delete instances in the print/ report so it resets after each run the issue we are having is that the graphical analysis for the second and third parts measured is not the same size as the ones in the report for the first one so we cannot see the arrows to show distortion in the parts. Is there a way to lock its size and position for every time the program runs??
