I am having an issue in using the "Relative To" option. For example I create and measure an edge point and an adjacent surface point which is nominally 1 MM from the edge. I have set the surface point to be relative to the edge point. It is my understanding that the surface point in this scenario should always then be taken 1 MM away from the edge. Let's say I have an edge point nominally at 10 MM in the +Y axis and is actually measured at 10.5 MM. My surface point should be taken at 9.5 MM. I have noticed that setting the "Relative To" is not working as I understand it to. When reviewing the actuals the surface point is being taken taken at the original nominal location as if the "Relative To" has no effect. Any ideas here? Thanks!
"Relative To" issue...
by CathyLooking for insight, only occasionally when I create an edge point it will show different results as a surface point at the same location. The surface...
04-14-2010, 11:59 AM -
by BSmithCould someone with a little spare time (lol) explain the differences between a vector, surface, and edge points in simple terms. I totally understand...
04-22-2015, 12:03 PM -
by markb4062I want actual xyz measurement in an edge point. I have tried using Expression Builder but it keeps saying that it is an Invalid Expression. Any other...
10-03-2006, 01:03 AM -
by tiborsomogyiHi everyone,
i have a question. I want to measure the contour of the glass, but around the surface of the glass by the edge is little wavy,...-
03-06-2014, 08:57 AM -
OK, I know I am going to be in for a lot of ribbing on this one, but here goes:
I have a part (no fixture yet) that I have to do an iterative...-
06-21-2007, 09:46 AM -
