As shown in photos I cant call out this true position I think its datumed incorrect but figured before I contact the customer for a 3rd time I would ask anyone on here if theirs anything I can do about this.
Getting Error On Datum Callout Any Advice?
If B is an angled surface to A and for this discussion B is your ( X) Where on that surface is B going to be measured from ? Depending where you take hits ? I see the 24.46 BASIC but thats not what DMIS is going to give you when you use a PLN .
Looking at wrong callout but I guess it really still applies...
Try to construct a plane with the 3 X 6MM D datum features, I am thinking that the 38.36 Basic is driving the D relationship, does not like the relationship of the ID X 3 that construct the D datum and the B datum.
Are your D datum features circles or cylinders? What is M1?
I'm using circles material thickness is like 2mm honestly M1 i was wondering the same thing but its a note in the rev box that says updated datum features
i tried and i aligned using D as primary C as secondary and B as tiertiary then it kicked back a error saying lower tier primary must be the same as upper tier primary
Looking at this closer, D pattern and as drawn 38.36 Basic questioning to D why not from A datum for 38.36, does not make sense from D datum. D pattern would be centroid of pattern?? Feel like missing something.
34.16 Basic and 38.36 Basic going to same features?
Are A and C not 90 degrees?
Schlag question on the 24.46 is a good question also, unless not seeing that the Basic is angular, the view with D MMC C and B callout are skewed.
Looks like you have a "FUN" part here.
by TAC45A couple of questions about true position call outs for datums.
1) I have a 4 Way "B" Datum hole. This hole resides on the primary...-
02-07-2019, 01:51 PM -
First off, howdy. Im fairly new to PC-DMIS. I'm catching on pretty quickly, but im stumped on this one particular call out I've run into on a print that...
06-10-2014, 05:57 PM -
by ShankCrusherAttached is a crude Excel version of the drawing I am posting about.
Having a discussion today on this really simple alignment and position...-
02-25-2016, 03:17 PM -
by BrandnewHi all,
Two questions relating to the attached file.
1) Datum C is called out to be Perpendicular to Datum A. However will "flatness"...-
09-09-2009, 03:39 PM -
Good Afternoon all,
I have a question that has been bothering me for a while, I posted a sample of the code. I am measuring the position...-
Channel: PC-DMIS Portable
06-12-2020, 02:27 PM -
