Hello,
I did a calibration check program reporting results from X,Y,Z axis plus ball sphere diameter.
I set tolérances at +/- 0.005 for X,Y,Z coordinates and +/- 0.0025 for sphere diameter.
Everything is fine except disc probes due to calibration method (the angle is very narrow on the Z axis +/-7°) :
What should I do to properly check this probe on Z axis ?
Thank you
CASE 3_TIP 1_RES | Emplacement des dimensions (CASE 3_TIP 1) | X | 0 | -0.00324 | 0.005 | -0.005 | -0.00324 | 0 | |||
CASE 3_TIP 1_RES | Emplacement des dimensions (CASE 3_TIP 1) | Y | 0 | 0.00069 | 0.005 | -0.005 | 0.00069 | 0 | |||
CASE 3_TIP 1_RES | Emplacement des dimensions (CASE 3_TIP 1) | Z | 0 | 0.01786 | 0.005 | -0.005 | 0.01786 | 0.012861682 | |||
CASE 3_TIP 1_RES | Emplacement des dimensions (CASE 3_TIP 1) | D | 24.99775 | 24.99829 | 0.005 | -0.005 | 0.00054 | 0 |
Thank you
