I can calibrate Disc probe but i need to check groove width as Datum and grove width is only 6mm. with the help n5000-7810-02-a (disc Probe ) we planned to inspect width also please help me to calibrate Roller with disc probe
Disc probe Roller Calibration
Originally posted by AndersI View PostPC-DMIS does not support the rollers on disk probes, but I faintly remember someone mentioning a working method in another thread - search the forum a bit, and you may find it.
First, calibrate another normal probe in the exact spot you want to calibrate the disc probe, this way you can answer ''no'' when it asks you if the calibration sphere has moved.
Second, make sure you do NOT have DCC+DCC chosen in the calibration options. Choose ''DCC'' instead.
Third, check ''user defined'' instead of ''default mode''
I usually run 12 hits with three rows.
Next, figure out your start and end angles by using the math below.
18mm disc dia x 2mm thick
Calibrate using only 70% of the disk thickness (out of square comp.)
2mm x .70 = 1.4mm
half of 70% thickness
1.4mm / 2 = .7mm
Half probe dia.
18mm/2=9mm
Calculate the angle from horizontal center line to half disk thickness
SineA= .7/9
A=4.4º
Start angle -4.4º
End angle 4.4º
Note the start angle is negative and end angle is positive.
This is all information I compiled in my thread when I was having trouble. This worked like a charm. Dont thank me, thank the forum.
- 1 like
I was asked this by a friend who has limited internet access.
I don't use disc probes, so can't help....-
07-14-2011, 08:55 AM -
by ghuntzingerI have not been able to find specific answer on old threads as to how to calibrate a disc stylus in DCC. Touching off with the post normal to the cal...
04-28-2010, 11:48 PM -
by EBUSHI have been trying to use my ruby disc probe but i can not get any of the dia. or runouts to come out correctly. I calibrated it manually like it says...
11-11-2009, 12:07 PM -
by Jay_QDoes pcdmis support a disc probe with a roller? If not, can one still be used to probe a groove thickness by turning off probe comp. and how accurate...
10-27-2020, 10:29 AM -
by HirxmOk so this is the second time I ask how to calibrate a disk probe. The thing is that PC-DMIS doesn't let me calibrate a disk probe as it should. This...
08-30-2019, 12:09 PM -
