Again I am new for disk probes is there a preferred angle range being they are not spherical it puzzles me.
Calibration Start and End Angles for disk probes
hello
you can use this calculation to figure out ur start-end angle.
example:
18mm disc dia x 2mm thick
Calibrate using only 70% of the disk thickness (out of square comp.)
2mm x .70 = 1.4mm
half of 70% thickness
1.4mm / 2 = .7mm
Half probe dia.
18mm/2=9mm
Calculate the angle from horizontal center line to half disk thickness
SineA= .7/9
A=4.4º
Start angle -4.4º
End angle 4.4º
- Likes 2
by Marty SchwabI have not used many disk probes. I calibrated a 25mm dia X 3mm With 12 hits and start angle of 10 end angle of-10 i got good calibration results but...
03-31-2006, 09:34 AM -
Does anybody know how to calibrate a disk in PCDMIS 2010 MR2.
Im getting out of calibration disk by 2 mm or so, because when I send to calibrate...-
11-09-2010, 02:22 PM -
by bpenningsDoes anyone have a documented procedure for calibrating disk probes? The PCDMIS procedure does not work for me for some reason. It is 18mm in dia. and...
04-22-2008, 05:22 PM -
by carlstesslHi all!
Question? how do I calibrate disk probe's so i can utilze the spheres (bumps) that are located on the top and botttom?
02-15-2011, 01:26 PM -
by WolfManHello gang, I have not used a disk probe (18mm dia, 2.6 THK, not a Cylynder probe), in a whle, when I use more than one Level to calibrate it, it tries...
01-30-2016, 07:37 AM -
