Saving each part program run
  • SingularitY
    Scripts are useful. I have one that autosaves the program after each run into a folder specific to each cmm, then it will automatically delete the .cad file afterwards. Network storage can fill up fast otherwise. Also, one that creates the part number and job number folder before saving a report if it doesn't already exist. I'm sure if you use Shrocknrolls link you can make changes to have it do what you want. Otherwise, I can post some code later on with a description of what needs changed to work with your system.
  • Schrocknroll
    https://www.pcdmisforum.com/forum/pc...rchive-freebie
    This might work, or at least point you in the right direction.
  • oddam
    started a topic Saving each part program run
    I need to save each part program I run from now on. Currently I "save as" and serialize the program into a part folder. Problem with doing this way is if I forget to save a program because someone has me doing other items, then I forget to save. This happened on a couple studies. Is there a way to save the entire part program at the end with an automatic pop up like a save as? I have never known of one in pcdmis, but it would be nice.
    Odda
