Hello! I am having trouble trying to dimension to an intersection point created by two constructed best fit lines. The dimensions (.150 and .250) are not measuring at nominal even though it is programmed off the CAD model. I made the constructed lines from auto vector points that are set to measure at the nominal dimensions as well. The same thing is happening when I try to measure the angles (20° and 45°) from two constructed best fit lines. Any help is appreciated. Thank you!
Here is what the part looks like.
