Evening all,
I'm doing a analogue scan along a surface that has some tight rads. I've noticed that a particular small rad of 2mm does not output all the points of that scan when i either A, ask for the profile, or B break out the scans as points. (please see the photo below of the issue i am getting). Im currently inspecting this profile with a 2mm ruby . The probe appears make full contact with the surface. I've changed to a 1.5mm to test but still have the same result.
im using an SM25 module to do so
https://i.ibb.co/g4w4HRZ/test1.jpg
Direction 1 tech set to line
Exec control set to defined
nominals method set to Find nominals, tolerance set at 4mm
Ive changed the exec controls to relearn to see if this is the issue as the probe might not be hitting the surface but this isnt the case. Ive uped the tolerance aswell just to see if this rad is way out but this again didn't change.
boundary type - plane, 2 crossings.
If i break the scan to points i am able to take a hit on all points as a touch probe
If i break the scan to points after scan execution then points are missing along the rad when i break out
the t values for this individual points are around 0.7 so they should be registered by the scan
Any suggestions would be great.
Thanks
Thanks
