When I create an auto circle the graphical representation of the cir is above the actual cad circle. Does anyone know why this is happening?
Hole problems
I've seen that before. I believe it depends on the way the CAD model was created and possibly the type of file used for translation, e.g. IGES, STEP, etc. Sometimes the hole as generated through the body of the part is seen separately from the chamfer. It's annoying, but not without an easy work around. Just make sure the depth is bigger than the chamfer, as Douglas said.PC-DMIS 2016.0 SP8
Jeff
by FutureManIn previous life, I got used to a lot of Tarus functions, such as the ability to move stylus into a circle, hit a command, and the probe would move to...
01-16-2009, 12:00 PM -
We've recently upgraded to PC Dmis 2018. And ever since then, I am unable to take an Auto Circle on a pin. There are times where i can't reach the hole...
07-12-2018, 09:32 AM -
Does anyone know what button will make the probe travel to the center of a hole before measuring an auto circle?
03-27-2009, 04:22 PM -
by GWOLLNERLets say I was measuring a 10" inside diameter. Using "find hole" would start at the center and move outward until contacting the part....
11-27-2013, 05:59 PM -
by mconklinI am trying to check a auto circle and the part is thin and it is bottoming out when finding center and was wondering if there is a way to shorten up...
10-14-2010, 01:34 PM -
