Release Notes - 2019 R2 SP1
• PCD-36046 - Fixed an issue where the find hole option would not work with
the Wenzel interface.
• PCD-109698 - Fixed an issue where performance was decreased during the
execution of a laser scan and COP commands in a loop.
• PCD-132016 - Fixed an issue where PC-DMIS stopped responding when you
ran the Zeiss interface on new computers. This fix also enhanced the
performance of the execution of many independent features.
• PCD-156784 - Fixed a crash that occurred when you used a 4 bit-per-pixel
bitmap for the CAD texture.
• PCD-158609 - Added support for DEVA 037 Manual Counter Card. To use this
interface, you must rename MANUALCMM.DLL to INTERFAC.DLL, and
GMS_for_Deva_EncLib.XML to GMS.XML. All files related to the DEVA card are
installed with the DEVA driver.
• PCD-158646 - Fixed an issue where the pointcloud cross-section Show/Hide
distance gages button was disabled in the Slideshow view.
• PCD-167625 - Improved compatibility with some USB serial cables used to
connect the HP-C-VE controller to the PC via USB.
• PCD-169328 - Fixed an issue where PC-DMIS did not pass the surface ID to
the command when you created a 3D Laser QuickFeature and had to re-pick
the CAD surface from the Laser Auto Feature dialog box.
• PCD-169386 - Fixed an issue where the points went to the wrong surface
when you picked point pairs in a pointcloud to CAD alignment. This issue
depended on the view orientation.
• PCD-169906 - Fixed an issue where pointcloud stripe IJK information was not
included in the Pointcloud | Export XYZ file format.
• PCD-170207 - Added a change for the PointcloudOperator |
ExportXYZSeparator registry entry to define one or more separator
characters used for the Pointcloud XYZ export.
• PCD-171304 - Fixed an issue where PC-DMIS reported the worst point instead
of the measured centroid for non-plane features.
• PCD-171381 - Fixed an issue with a Chinese operating system where settings
to execute the collision avoidance during calibration were not read correctly
from the registry on machines.
• PCD-171396 - Fixed an issue where the Mesh colormap annotation points
were not created unless the measurement routine was closed and then reopened.
• PCD-172057 - Fixed an issue where the news feed on the Home page was
empty for Chinese (Simplified). It now uses Chinese (Traditional).
• PCD-172202 - Fixed an issue where PC-DMIS did not obey the marked set's
output settings when PC-DMIS executed a marked set.
• PCD-172853 - Fixed an issue where the execution of laser probe calibrations
from the auto-calibrate command didn’t finish. The Execution dialog box
had to be closed through the Stop button.
• PCD-173186 - Fixed an issue where the Home page was switched off when
the Part/Machine Setup tab was the active tab in the Setup Options dialog
box.
• PCD-173227 - Fixed an issue for laser auto cylinders and spheres where the
CAD offset value was incorrectly applied for inch units.
• PCD-173264 - Fixed a timer functionality for the CMM-OS interface.
• PCD-173687 - Fixed an issue that occurred when you executed toolkit
module features.
• PCD-173721 - Fixed an application error that occurred when you created a
linear open scan with a CWS probe, and the Measure option was selected in
the Linear Open Scan dialog box.
• PCD-173743 - Fixed an issue where the measurement routine stopped
responding if you opened the Tilt Readouts window (Tracker | Nivel | Start
Tilt Readout) for the Leica ATS600 Tracker.
• PCD-174456 - Fixed an issue where the Home page overrode PC-DMIS locale
enforcement for decimal numbers, which caused issues with entering
numbers of specific locales.
• PCD-174671 - Fixed a Vision probe-focus calibration error that occurred
when the Find Surface (Focus) parameter was incorrectly enabled.
• PCD-174797 - Fixed an issue where the Tracker Operation toolbar was
missing the measurement profile buttons for the AT40x Leica Tracker
interface.
• PCD-175045 - Fixed an application error that occurred when you edited or
executed a Vision feature with multiple hit targets.
• PCD-175460 - Fixed an issue where, after the machine left a probe change
rack, PC-DMIS computed an incorrect mount-point move. This issue caused
either an incorrect movement or an "out of machine limits" error
