I have a problem with vector points today. For some reason PC-DMIS is offsetting the hit target parameters which causes the machine to crash. The hit target parameters must match the X,Y,Z location of the point. It only happens on some points. If I manually correct it and execute it then it works until the program is closed and re-opened. Then it crashes again. It's driving me crazy. Wrote the program in 2019R2.
Vector Point Problem
Originally posted by dtmtim View PostThat's what I thought as well. I have never used void detection on vector points. The button shows that it's on but it's greyed out and I can't control it.
The only other thing that I can think is to check and see if your theo X, Y and Z's are the same as your target X, Y and Z's.
That "Hit Basic" line of code is what is killing me. I can set it to the correct values but when the program is closed and opened again it goes back to the bad values or if someone F9's the point it goes back to being bad.,Global Image 555
PH10M-TP200
PC-DMIS Cad ++
Win7 64 bit
V2014.1
Thank you, no offsets are entered. Only about 5 of the 100 vector points are affected.Global Image 555
PH10M-TP200
PC-DMIS Cad ++
Win7 64 bit
V2014.1
by B. JacobsI am having some trouble here.I would like to know how to make a vector point hit in the same place more than one time. What I mean is this:
I...-
03-02-2007, 02:33 PM -
by 12345What is the difference between a measured point and an auto vector point?
08-18-2008, 02:21 PM -
by skellyUsing v2016 sp2. I measure a Vector Point having the SNAP function active and use a 0,0,1 I,J,K vector. When I look at the results of the point I expect...
09-12-2016, 04:28 PM -
by louisdHi all, I've got a closed scan that consists of mainly 8 arc-segments. I'm trying to extract 4 of the eight arc segments, which make a pattern in the...
05-01-2019, 05:36 PM -
by ELaFever2Howdy everyone, I'm trying to get my scans to register the measured values and use them as nominals for future scans. But all the points don't seem to...
09-08-2016, 11:09 AM -
