We received a program from a third-party for the profile of a part we are having trouble with. They have taken 19 separate points along the area for the profile check. The way they are measuring this profile is using "T" for a Location Dimension. I used the same program but changed the way of measuring by setting up the datum's and using the Profile measurement. The profile from both ways of measuring are different (using the actual Profile Dimension is reading more nominal than the Location Dimension). I'm wondering which measurement is the correct one to use.
Best way to measure a Profile.
ok so If you treat each point individual you get separate readings, Make sure you report out Max and Min in your report. Profile will take the highest point and the Lowest point and add them together to give you a MEAS result. But if you see the MAX and MIN it will show you the result of your highest and lowest point taken. That should show you the same as your "T" value hits, well at least 2 of them, Highest and Lowest
Capture.JPGLast edited by KIRBSTER269; 09-19-2019, 01:15 PM.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
by BKulpaI'm sure this has been covered before but I can't find it this morning.
Profile 0.1 / 10
Where the engineer is trying to control abrupt changes...-
10-09-2019, 08:13 AM -
by blackwaterIs there a form in PCDMIS dictating the proper way to dimension profile tolerances? We are having a debate between Polar radias reporting versus T value...
12-18-2008, 02:44 PM -
by pab39Hi,
I have to measure these 2 FCF on this drawing:
OK for the 2D profile, as we have an Optiv 321GL, i'll align...-
08-31-2020, 10:56 AM -
by Sl33stakThis is going to show everyone how little I know.
I have 5 profiles to check on a part. (form and location) I am checking each...-
05-10-2007, 12:07 PM -
by PacMan23I have a part that has a profile called out to ABC and a tolerance of +,- 3mm but the part is fails when measuring on CMM. So here at work an Engineer...
10-19-2017, 05:05 PM -
