Hi Everybody,
Does anyone know if there's a way to access the probe changer mount point (where it goes immediately before and after changing tips with the rack) in the code for a program? I'm thinking of shaving off a few seconds by using a MOVE/ALL command on the way to and from a tip change, but I need to know where to send it to. It would also be nice to be able to send it to that point at the end of the program without having to actually change tips.
Thank you!
Matthew
Edit: Upon further investigation, it's more complicated then I thought: it looks like the XYZ numbers in the "Mount Point" tab under Calibrate/Edit > Probe Changer are to the end of the quill, not the position of the probe tip. This would fit with how the machine moves prior to a tip change; however, replicating that action in the program requires either getting the machine to move the end of the quill to a point or manually de-compensating for the length of the probe (a big pain).
Thank you!
Matthew
