Hey guys, if you have a master part that is used to set the gage to zero or used for comparison relative to parts made, what kind of tolerance would the Master have? Or how would it be calculated? I am assuming Master part would have an combined uncertainty of the Gage and the process used during calibration.
Uncertainty of a Master part
About uncertainty, I would :
Measure a Koba step in many locations (parallel to axes, along diagonals planes and 3d diagonals), repeat the measurements (all steps) and calculate the standard deviation of all deviations (S1).
Measure a calibration sphere with many points (150), and calculate the standard deviation of radius deviation of each hit (S2).
Measure the part in different locations on the cmm, and calculate the standard deviation of each dimension (S3i)
U=±2*SQR(S1^2+S2^2+S3^2) should be the best uncertainty accessible on the part, around the average of each dimension.
In the first and second steps, the average of deviations should be very close to zero.
Trying to calculate the uncertainty of the distance between a plane and a point should take into account the flatness of the plane...
It becomes quickly very hard if there are a lot of dimensions...
- 3 likes
Measurement Devices have "Uncertainty", expressed as measurement units of expected error in the measurement results returned by the device.
Physical Objects, on the scales we operate on (i.e. human-scale stuff and as opposed to the quantum realm of particle-physics or the universe realm of astrophysics), are fixed and immobile - they have no uncertainty.
What you are looking for is the Uncertainty, not of the part, but of your CMM. The CMM should return the exact same results, within it's stated uncertainty as found in it's latest calibration paperwork, on an undamaged and same-temperature "known quantity" master part.
/thread.
- 1 like
No. I am not looking for uncertainty of a CMM. The feature in question is not even measured on a CMM. My question is about a Master part. I made an assumption that a Master part is just like any other Gages like a ring ID gage or a Gage Block. In both cases used to set gages or as a comparison device. These gages typically come with uncertainties, fairly small yet they are there on the certificate. Master part is no different than any gage, there for should have uncertainty .
Originally posted by Ego Murphy View Post
Physical Objects (...) have no uncertainty.
Uncertainty comes only from the fact of observing a quantity.
Most of units come from definition of the time.
A second has no uncertainty, but all national laboratories (NIST, LNE, METAS, PTB, NPL...) gives a different value of it (very very little difference - relative uncertainty around 10^-16 !!!) coming from there own uncertainty.
The main problem with Ego Murphy sentence is this : the work of the machinist is better than this of the metrologist!!!!!
- 1 like
Originally posted by WolfMan View PostNo. I am not looking for uncertainty of a CMM. The feature in question is not even measured on a CMM. My question is about a Master part. I made an assumption that a Master part is just like any other Gages like a ring ID gage or a Gage Block. In both cases used to set gages or as a comparison device. These gages typically come with uncertainties, fairly small yet they are there on the certificate. Master part is no different than any gage, there for should have uncertainty .
Originally posted by JEFMAN View Post
I must agree with that ...
- 2 likes
by MidwayI could use a few of your thoughts on this problem. Currently I am in the process of modifying assembly sub-components programs to use the current stampings...
03-03-2007, 03:28 PM -
by acgarciaGood Morning,
I hate to add another master probe thread but I think this is a simple question which will get me a quick response.
07-24-2018, 12:00 PM -
by JoBLOCKOk, say you forgot which probe is your master probe. is there a way to find out?
02-16-2009, 01:00 PM -
by RANDYKHey all,
On the Zeiss machines and Colapso they have a master probe or tip to be calibrated first. This sets the rest of the tips to that...-
01-18-2011, 06:44 PM -
by Scott BrownGood Afternoon
I have read a number of posts regarding probe calibration and using a Master probe to relate multiple probes. I have a few...-
05-16-2017, 04:56 PM -
