Print Command issues
  • Print Command issues
    I'm having issues with a print command. Recently wrote a couple scripts that create a couple folders that the reports write to. Works well in test programs, but running it in a customer program, the folder are created, but the print command changes from OVERWRITE to AUTO, and opens up the prompt to save ignoring the assignment with the file path. Any insight would be appreciated.
     IF/C4.INPUT=="1"
                    ASSIGN/SAVEPATH=""+PATH+"\\"+JOBNUM+"\\"+OP30+"\\"+V1+"_"+V2+"_TOP.pdf"
                  END_IF/
                  IF/C4.INPUT=="2"
                    ASSIGN/SAVEPATH=""+PATH+"\\"+JOBNUM+"\\"+OP50+"\\"+V1+"_"+V2+"_TOP.PDF"
                  END_IF/
                  IF/C4.INPUT=="3"
                    ASSIGN/SAVEPATH=""+PATH+"\\"+JOBNUM+"\\"+OP90+"\\"+V1+"_"+V2+"_TOP.pdf"
                  END_IF/
                  PRINT/REPORT,EXEC MODE=END,$
                    TO_FILE=ON,OVERWRITE=SAVEPATH,AUTO OPEN REPORT=OFF,$
                    TO_PRINTER=OFF,COPIES=1,$
                    REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$
                    TO_EXCEL_OUTPUT=OFF,
    Which version are you using?
    Systems Integrator
      Cad++ 2014.1
        is 'SAVEPATH' a network location? Try saving locally, then use file/move to the network address.
        Also having three if/endif's without a default or 'else' command to error proof the input value might be screwing with the path creation.
        try using Select/Case and use default option at end.
        • louisd
          louisd commented
          make an operator comment that == C4.Input prior to your print command, see what's being produced.
          If C4.input is only going to be an integer: 1, 2, or 3, just put IF/C4.Input==1 --remove the quotes.
        Turned out to be an issue with the order I had marked the program up for Marked Sets. All works now, thanks for the help.
        I have logic in the program at a different location to avoid any errors in the path creation, but I'll look into using Select/Case in the future.
          do you think you could help me with the create folder? My last shop we had a .bas or .exe that would create a folder of the serial number / job number or whatever we needed. I know how to assign the veriables and such. I just need the script for it. Would be greatly appreciated.
          -riley Lawlor
          Southern California
          Aerospace CNC Machinery
            Here's a start.
