Reset Values
  • Reset Values
    Hi,
    I search a lot in forum but I may using the wrong key words so here's the problem and question:
    I have to run the same routines a few times (5 to 125) for each time i run the routine the previous value stays there and on the View Last Execute Report Mode, keeps adding pages and pages, and each time i ran a routine it's slower and slower.
    Thank you in advance...
    look and see if you have this in your program
    should be at the end
    look at the previous runs
    PRINT/REPORT,EXEC MODE=END,$
                  TO_FILE=ON,APPEND=V22,$
                  TO_PRINTER=OFF,$
                  TO_DMIS_REPORT=OFF,FILE_OPTION=OVERWRITE,FILENAME=,$
                  REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$
      Can I use this in any routine?
      Darroll
      2018R2
        yes
        the file/printing/report window print setup/ "report print window" should be all unchecked
        also - if you want a header on each report, after print command block need to add this
        REPORT/LABEL, FILENAME= FILE_HEADER.LBL
        before line of code to return your logic run next part in multiple part execution
          Sounds like your using "execute from line" and not restarting the execution.
          Systems Integrator
            File/Reset Execution List will also clear out any prior commands that were executed.
            The list is cleared upon a start of a full execution but not upon any other type (execute block, execute from cursor, etc) which is why you are seeing multiple executed commands.
