Qualifying tips
  • Qualifying tips
    Hi , trying to qualify different tip angles. Where is the setting to raise the probe so that probe doesn't hit table when rotating.
    Thanks For any help Brown & sharp CMM PCDMIS 2014.1
    Dennis g.
    Dennis G............Don't worry Wilson! I'll do all the paddling! You just hang on!---Castaway
    In the probe utility window, click Setup, then in the section Clearance Distance you can add the distance along the qualification tool vector for non-continuous wrists.
    PC-DMIS 2016.0 SP8
    Jeff
    • Tammie Godden
      Angles
      by Tammie Godden
      Hi All
      I am calibrating probe/tip angles. All is good when I calibrate previously calibrated tips/tips that were already part of the probe...
      05-25-2006, 11:28 AM
    • tnguyen
      Need help caribration
      by tnguyen
      Hi everybody.
      I was so crazy for probe caribration today. I have learned to defined and setup parameter for Star probe from this forum yesterday....
      03-17-2007, 03:17 AM
    • doo_hicky
      Tip calibration
      by doo_hicky
      When I calibrate my tips there are a few build ups that can collide with the cal sphere. I know that I can do the user defined order, my question is...
      04-25-2008, 06:45 AM
    • AA/Altered
      Probe Certification Recalling??
      by AA/Altered
      I have a question about probe qualifying. If I have a probe that has 20 or so tips in it and I run a part and "mark used" and it only qualifys...
      02-11-2010, 07:08 AM
    • PCDEMON
      Tip Calibration order
      by PCDEMON
      4.3 MR2 PH10MQ head TP200
      When calibrating tips there are 19 different probe angles to be calibrated for a specific probe. When user defined...
      04-27-2010, 09:37 AM
