Repeat the measurements
  • Repeat the measurements
    I generated a program to check one part today and if I have to measure more parts with the results in the same report. How can I do that. right now I am executing program for each part seperately and generating multiple reports for same type of part. I also didnt want to run initial instructions(like fixture setup) everytime as it is waste of time.
    Thank you for the help.
    Change report window print options from Auto to Append
      It looks like you want to loop the entire routine. You can use flow control and operator comments to ask if they want to see setup notes or not. Add a comment in the loop to tell the operator to unload the current part and load the next one.
        I agree with the posts above. Also you can try to skip the unwanted features using F3 and "Marked Sets" as another option instead of flow control
          Yeah, I was thinking that I need to add some loop statements in the program to do that but wasn't sure. I will try that and see. I will also look into Auto to Append option. Thanks for the prompt response.
            I believe you mean Overwrite to Append.
            PC-DMIS 2016.0 SP8
            Jeff
            • RandomJerk
              RandomJerk commented
              I thought it defaulted to Auto, unless I completely missed that OP had already set it to Overwrite.....
