Standard stylus not showing up??
  • Standard stylus not showing up??
    Ok, I ordered a standard 3mm x 12.5 stainless Steel barrel probe stylus from Renishaw. Went to build it up, and its nowhere to be found in the drop-downs. Anyone have any idea how to get this probe built up in the probe utilities dialogue?
    EDIT > PREFERENCES > CUSTOM PROBE BUILDER UTILITY. Or if you prefer to go old school you can edit the probe.dat file (found in the install directory).
    Neil Challinor
    PC-DMIS Product Owner
    E: [email protected]
    • AndersI
      AndersI commented
      Or rather add a definition to USRPROBE.DAT - probe.dat should not be modified, as it will be overwritten in the next update.
    3x12.5 : 12.5 is the B dimension or EWL ? (overall length, or effective working length ?)
    Maybe it's a 3BY20, with a EWL of 12.5.
      Sure it isn't Ø3x22.5? Renishaw number A-5003-1258? That's in there.
        Hi everybody!
        I struggle with that too, where did I mess it up?
        https://renishawprobe.com/p/Styli/Cy...M2/A-5004-7590
        ITEM:TIP3BY13MMtcSHANK M2
        begintip
        ribcount 10
        color 142 142 142
        cylinder 0 0 0 0 0 -2.5 3
        cone 0 0 -2.5 3 0 0 -5.35 1.5
        cylinder 0 0 0 0 0 -7.6 1.5
        cone 0 0 -7.6 1.5 0 0 -9 3
        color 80 80 80
        cylinder 0 0 0 0 0 -12.75 3
        cone 0 0 -12.75 3 0 0 -13 2.5
        hotspot 0 0 -13 0 0 1 2.5 13
        endtip
          begintip
          ribcount 10
          color 142 142 142
          cylinder 0 0 -5.35 1.5 0 -7.6 1.5
          color 80 80 80
          cylinder 0 0 -9 3 0 -12.75 3
          endtip
            Dear Jefman, the finish:
              Sorry, I wrote cylinders as cone (8 values instead of 7...)
              This one should work...
              begintip
              ribcount 10
              color 142 142 142
              cylinder 0 0 -5.35 0 -7.6 1.5
              color 80 80 80
              cylinder 0 0 -9 0 -12.75 3
              endtip
              PROBFILE.zip
                That's how it turned out, thank you very much!
                begintip
                ribcount 10
                color 142 142 142
                cylinder 0 0 -5.35 0 0 -7.6 1.5
                color 80 80 80
                cylinder 0 0 -9 0 0 -12.75 3
                endtip
                (setup TIP diameter - error is more than: 1
