2019 r2 xact measure list not loading___build#202 release
  • 2019 r2 xact measure list not loading___build#202 release
    I am getting the wheels of death waiting for the feature list to load..?? not seen this before.
    Are you running slow/bogging in any other situations or during general use?
      no, nothing out of the ordinary
        And I assume (only a few features) that you're working with a relatively simple program?
          I can't duplicate. I opened a 6MB program with a lot of scanning and did not have this issue. Also on 202.
            half a dozen auto cylinders with concentric circle scan. not too dense. Doesn't work in 2019 R2 or R1..gonna reset product and try again
            • Don Ruggieri
              Don Ruggieri commented
              before you Reset Product, you should try Reset User. It is more specific
            tried both. It seems that when the dialogue opens, if I click the cylindricity icon in the FCF and select something else, the list populates, I switch back and it is ok. If I close and reopen, it starts all over again.
              Benedictj1 , Don Ruggieri
              I can duplicate it. It only happens when *all* available cylinders use the strategy "Adaptive Cylinder Concentric Circle Scan" - if there is any other strategy in any cylinder, the list populates directly in my test.
              I ran my test in the internal build #218
                hello.
                its been a few months since the last post to this thread. Was this ever resolved? if it was, what was the 'fix'?
                I am having similar issue , except when i click in and out of the cylinder list (adaptive cylinder), it crashes the software.
                thanks
                Global A 9128, Global S 9128, Global fx7107, microhiteDCC
                  The original problem is there still in 2019 R2 SP2 (#317). The workaround in that case is to always have at least one cylinder measured with some other strategy - then there's no problem.
                    AndersI is it possible for you to test this in 2020? Seeing it is still in technical preview, maybe this can be fixed prior to 2020's release?
                    Thanks in advance.
                    PC-DMIS CAD++ 2o22.2 SP3
                      vpt.se - I just tested and I do NOT get the problem in 2020 Beta #135. Seems to be fixed.
                      • vpt.se
                        vpt.se commented
                        Thank you!
