What is the best way to align to a part with all wavy surfaces?
Alignment
- 3 likes
JacobCheverie I don't know if an iterative will work. I'd try an iterative instead.
Don't flag me bro...
I tried the iterative alignment and could not get it to work. I ended up getting it to work using a best fit 3d vector least square with no weights.
How did the iterative not work (no joke here)? I haven't run across a part yet where an iterative wouldn't get the job done.
Can you post a pic of the part or a general sketch (in case of ITAR or proprietary)?
I'm not doubting you at all. On the contrary, I'm just wondering why it didn't work in case I run into a similar part.
by skip fullonHi folks,
Im often use 3-2-1 alignment for all of our mesurement routine.
My question is can i use iterative alignment...-
04-17-2020, 01:13 AM -
by RussLWe have some parts that are mostly curves (airfoil shaped).
They lie in the aircraft coordinate system at very odd angles.
When these parts...-
11-20-2007, 11:02 AM -
by Dave2254I am new to using iterative alignments and have used 3-2-1 and best fit alignments in the past. When using an iterative alignment, do I need to create...
08-17-2016, 08:35 AM -
I got this one program that uses iterative alignment and whenever i try to execute just one feature of the alignment (cylinder for datum B and/or C),...
10-03-2014, 09:16 AM -
by N3WPVI have a free-form sheet metal part I need to compare to a model. I establish an external alignment on a fixture then place the part on the fixture and...
05-15-2012, 08:12 AM -
