Print resolution PC DMIS 2019 R2
  • Print resolution PC DMIS 2019 R2
    Hello
    I need some information. When I print a PDF control report the quality of the PDF is much worse than what I have on the screen, the graphics and tables are like "empated". I
    was in the settings editor to watch and found MaxPrintResolution.
    The current value is 1,000,000. Do I have to set this parameter?
    Thank you in advance
    Best regards
    That value means "as much as the pdf driver can manage" which should be much more than you need. 300-600 dpi should be enough for most printing.
    Try changing Reporting/HighResLegacyOutput and/or MaxImageRatio and see if it makes a difference.
