I am trying to set up barcode scanners on our CMMs so that when the operator puts a part on the fixture, they will scan the part and it will automatically open the proper program. If this kind of thing possible? I have seen some people using scanners to add data via comments, but is it feasible to scan a part and have it open the corresponding program?
Using Barcode Scanner to Open Programs
JoBarcode is an old program, and only supported on the Nordic market. Take a look at Inspect instead - it's part of the PC-DMIS installation if you have a recent version.
I think both programs currently have the same limitation - the barcode must be the part program name. JoBarcode will not change, Inspect is actively updated, and you can suggest improvements on the userecho pages, https://hexagonmi.userecho.com/Last edited by AndersI; 09-03-2019, 05:56 AM.AndersI
- Likes 1
Some companies using JoBarcode have produced a paper folder, with part descriptions and barcodes for one or more programs created for each part. They don't scan the barcode from the part as it is some completely different number with lots of other information. They just scan the applicable barcode in the folder.AndersI
I use operator mode and set the default search path to an operator programs folder. The operator hits a file open hot key, then scans the barcode for the program.
Inspect works well for this as well, Inspect bogs down my computer so I don't use it, not sure if its the settings I have, old computer or whatever, but operator mode works fine for my purposes
Thought I saw a camera from Hexagon that would mount to the bridge of the CMM. It would recognize the part and then open the correct program. Can't find it now but ...... Unless I'm going senile again.
IMO inspect will do the trick not only opening programs but also assigning tracefields from the same barcode such as WO number or Lot number etc. Creating the barcode to do all these is another topic but still easily doable. Keep in mind while Inspect is free, the barcode functionality comes with a license of a couple ks
I know this response is coming a bit late, but for anyone else who might have the same question, it's definitely possible to use barcode scanners to open programs. In fact, it's a common practice in many industries where barcodes are used to manage inventory and automate processes.
Originally posted by kbkhan View PostI know this response is coming a bit late, but for anyone else who might have the same question, it's definitely possible to use barcode scanners to open programs. In fact, it's a common practice in many industries where barcodes are used to manage inventory and automate processes.
by SamsdadmattGood Morning you lovely people
I am trying to scan the profile of this gear but i can't seem to get it to finish where i am telling it to! it finishes...-
12-02-2016, 04:55 AM -
by MansukhWhen ever I try to scan linear open on curved (Radius curve) surface a message pop up for not finding the part. Is there any special method for curved...
05-31-2012, 10:10 AM -
by GWOLLNERI just started a new job and they are using pcdmis" V3.5 CAD". The CMM has a TP2 and a ph10mq. Im trying to do a linear open scan without CAD....
11-19-2010, 07:28 PM -
by mx07423I'm trying to do some laser scanning on my cmm we have a Scanshark V4. The problem i'm having is that when i make a linear open scan the head doesn't...
10-01-2009, 10:55 AM -
by tdracerI'm trying to do a simple linear open scan. Just a straight line.
I take the first hit, 2nd hit for direction, and 3rd hit for ending point....-
02-13-2009, 11:05 AM -
