Has anyone ever seen a probe stylus that had a true flat edge on it? I am trying to measure a point on a fan blade that is angled on a rounded edge. So basically, the edge of the fan blade is rounded, and we shave the diameter off to a point that it comes to a sharp point. I have to measure the dimension where that point sits down to the flat plate in the middle. Essentially, the "H" dimension shown in the attachment. I was able to get this dimension with height stand, using a blade, but I have never seen anything like this for CMM, and they specifically require cmm measurement. Ordinarily, we use a 2x20 shank probe to measure fans, but they also ordinarily have a radial measurement point. These fans do not. Anyone know of anything, or any where I could obtain a stylus that would work like a flat blade? I tried a disk probe, but the calibration off those is to the little nub on bottom, so the numbers were way off.
Anyone else have an idea of what I can use? At this point I am desperate enough to try anything, or maybe even buy anything.
