Hello,
I've been using this forum for years and normally it helps solving all my questions.
But today I've met my match, and am hoping some of you could help.
The machine is a Leitz PMM-G with LSP-S2.2 probehead.
De sphere with the blue arrow is the tip. It's diameter is Ø29.368 mm.
With this probe it should scan the 2x radius R15 at the green arrows. The centerpoints of these radii are not the same, they are 0.2 mm apart.
After that it should scan to the plane with the red arrow.
So basicly, when the tip touches all 3 surfaces the hitpoint should be taken..
I have another part with the same procedure, but with the plane (red arrow) not perpendiculair to the radii.
A bit harder to achieve maybe.
I hope someone has an idea on how to get this working.
Thanks.
Thanks.
