Midplane Between Two Radii
  • Midplane Between Two Radii
    If this was your primary datum, how would you replicate it in PC-DMIS? My only thought would be to do an iterative alignment on one side only...but that would throw everything out of location based on the width of the part. Could I do a best-fit alignment incorporating each side (I've never done one before)?
    Do you have scanning capabilities, or just a touchprobe? I you have scanning, I would construct a scan on one side, covering as much of the surface as possible. then, I'd copy/paste with pattern-> flip Y that same scan to the opposing side.
    -From there, you could do several things. you could simply try to construct a midplane from the two scans, (my guess is this won't help much), but you'd have to define the hits of each scan to do it correctly.
    construct -> plane -> midplane -> SCN1 & SCN2. then within the constructed feature you'd add .hit[1..SCN1.numhits], to end of SCN1, and the same for SCN2.
    If that fails I'd construct a handful of theoretical planes sectioning part along X. I'd then construct intersect lines for each plane, and construct mid-lines for each set of intersects. and finally stitch the line data into a constructed plane.
    For the implied origin that this inverted torus can imply, I'd construct a single cast point of the two scans.
      I would call the designer to explain him what is a cmm measurement, and how bad is his definition !
      • Lukas
        Lukas commented
        Hahaha it is that it's an op sheet drawn by our internal engineer. The customer drawing uses a different datum that isn't machined yet. Tomorrow is my last day so it won't be my problem anymore, but I thought I'd ask if this is possible to program.
      • JEFMAN
        JEFMAN commented
        Engineer or not, the drawing must have the same meaning for the designer, the machinist and the controller.
        If that does not mean anything, you have to explain it to the designer...
        It's rarely fun, but it's a way of improvement!
      • Lukas
        Lukas commented
        In theory it could be done though, right? For instance, if those radii were much fuller, then I suppose I could create a mid-line between the two cylinders. The engineers here are too stubborn--it's not worth the effort. I am just going to select a different datum that is as true to the customer drawing as possible.
      You're right, it's possible... You can obtain this :
      It's a datum, if the measurement is bad (less than my draw, but just a little wrong), what will be the result ?
      An engineer who can't admit his errors is a bad one !
        In all due respect, this is beating a dead horse here, if your last day having anything to do with inspecting this product is tomorrow. BUT I presume the A datum is not explicitly defined as a midpoint between a width of curved features on the print. My guess is there's some information left out of the picture here. Plus, we don't know any other view of this part.
        A datum might be a torus, like I presumed. You can get 5dof controlled with a torus.
          XactMeasure can use freeform surfaces (scans, sets) as datums - not sure what it locks, though. Can't be primary, I suspect.
          Edit: A quick test seems to indicate a set only locks XYZ, no directions.
            Well, you gave me an idea. I created a mid-plane between the scans. See my pics below. However, it looks crooked like JEFMAN's drawing. Thoughts on this? Anyway, I thought I'd just post this for learning purposes. It still doesn't seem like it's possible to use this datum. I'm using the ID bore instead.
              What about scanning both sides and do a bestfit alignment on the scan(s)? That should take care of the direction(s). If you actually *need* a midplane as a datum feature, you can construct it afterwards, from the current alignment.
              • Lukas
                Lukas commented
                I don't need an actual mid-plane. Yes, that is what I was hoping would be possible. I've never done a best fit alignment (only iterative). Iterative doesn't allow you to select a primary datum with drastically different point vectors. Does best fit?
              • AndersI
                AndersI commented
                Yes. You actually *need* drastically different point vectors if the bestfit is 3D - you need to lock all three directions...
              • AndersI
                AndersI commented
                Note: When you do it with the alignment, you need to use legacy TP, or create fake datum features from the alignment for XactMeasure.
              How's this look for a first attempt at best fit? I used the two scans, a midplane between the left and right sides, and a point on top of the part. My deviation was at .0008 so I set my deviation threshold to .0009 lol...
              https://i.postimg.cc/t4FgVPnr/Capture.png
              • #2#
                midplane
                by #2#
                I am measuring a plane on two oposing sides of a part. I want to create a plane centered between these two planes so I can measure how far from center...
                07-27-2006, 10:04 AM
              • d.evans
                .625" external hex as a Datum
                by d.evans
                How would you construct this?
                I do have the CAD.
                So far, I tried six planes (one on each surface of the hex) and then constructed...
                08-07-2006, 02:52 PM
              • tnguyen
                Parallelism
                by tnguyen
                Hi. I make path scan in two different areas, but they are in the same surface and then construct FEATURE SET then I apply Parallelism. Is it the right...
                04-23-2006, 11:27 PM
              • Evan.Smith
                Concentricity between two scans?
                by Evan.Smith
                I have a spec that requires Concentricity with Least Squares Centering of two diameters (about 4 feet across) with 180 data points on each diameter. I...
                09-27-2016, 09:53 AM
              • alanarnott22
                Mid-plane and perpendicularity
                by alanarnott22
                I am working to get perpendicularity out of a mid-plane. I have been searching for threads concerning the same issue. They mentioned using mid-points(constructed...
                02-26-2015, 06:16 PM
